StreamFab for Browser pairs a Chrome or Edge extension with a local CoApp on Windows to save content you are authorized to watch as local MP4 or MKV files. Choosing the right setup depends on the website, installation channel, and source quality; this guide covers capabilities, CoApp, and four setup steps.
For YouTube, the installation channel matters: the Chrome Web Store version does not support YouTube downloads, while the official website version does. This distinction is also useful when comparing YouTube video downloader extensions for Chrome and Firefox.
StreamFab Video Downloader for Browser: 4-Step Setup
StreamFab Browser Downloads Support up to 8K
StreamFab options depend on source quality, audio, subtitles, and MP4 or MKV availability.
For source-supported video-sharing content, StreamFab for Browser supports resolutions up to 8K and saves video as MP4 or MKV. The selected video, platform, and service plan determine the resolutions actually available. The quality selector and official trial provide a practical way to check the desired source before choosing an output.
  • Select from the resolutions detected for the current source
  • Save available original multichannel audio and choose an audio language
  • Choose available embedded or external subtitle options
  • Queue multiple videos when the supported source offers batch detection
This extension-and-CoApp split forms the dual-engine workflow explained in the next section.
The Dual-Engine Architecture: Plugin + CoApp Explained
How to install StreamFab, connect CoApp, select quality, and download on Windows.
The architecture uses two components: a browser extension as the user interface and a local CoApp for download processing on Windows.
The browser extension detects supported video streams as you browse and presents the available download controls. When you start a download, it sends the selected source, quality, audio, and subtitle options to CoApp for local processing.
The CoApp backend handles stream fetching, available audio and video track assembly, and final file creation at the selected quality. On Windows, you can open Task Manager to inspect CoApp's current process activity while using the installed product.
StreamFab CoApp backend for source-dependent downloads up to 8K
StreamFab Plugin + CoApp: Capabilities at a Glance
CapabilityStreamFab for Browser
Platform supportWindows with Chrome and Edge
Source-dependent qualityUp to 8K
Output formatsMP4 or MKV
AudioOriginal multichannel audio and language selection
SubtitlesAvailable SRT or embedded options
Batch downloadsAvailable for supported sources
Resolution, audio, subtitle, and batch choices depend on what the selected source and product option make available. Use the official trial and output selector to confirm the desired combination.
MP4 and MKV are output container choices, so use a player that supports the selected container and video codec. A platform's official offline feature can suit a quick in-app watch, while this Windows workflow is designed for local MP4 or MKV files with selectable audio and subtitle options.
How to Install and Use StreamFab for Browser
Chrome and Edge extension paired with a local CoApp on Windows. Detects supported video-sharing sources and offers source-dependent quality up to 8K, batch downloads, and subtitle options.
Step1
Download the official Windows installer for StreamFab for Browser, then follow its prompts to set up the browser extension and local CoApp. StreamFab for Browser supports Chrome and Edge, but installation-channel behavior differs. The Chrome Web Store version does not support YouTube downloads, so use the official website version for a YouTube workflow.
Step2
Open a supported video that you are authorized to access and start playback. Confirm that CoApp is installed and that the StreamFab icon or supported on-page download control is available in the browser.
StreamFab for Browser chrome extension download 4K video 2026
Step3
Open the StreamFab download control and review the options detected for that source. Select an available resolution, audio track, and subtitle option; available choices depend on the video, platform, service plan, and product module.
Step4
Click Download to send the selected job to CoApp for local processing. The completed file appears in the designated download folder as an MP4 or MKV. When batch detection is available for the source, add the desired episodes or videos to the queue before starting.
Detection checklist: Use the installation channel that supports the target site, confirm CoApp is installed, play the available video, refresh detection, and reopen the quality selector. If the video or expected quality remains unavailable, use the official StreamFab for Browser setup and help route for the matching product option.
Use StreamFab for Browser only with authorized access and authorized content for personal offline viewing. Do not redistribute saved files, and follow applicable law and platform terms; specific permissions depend on the use case. A downloader license does not include or replace a streaming-service subscription.
WHAT WE LIKE
  • Browser-based controls with local CoApp processing on Windows
  • Source-dependent quality options up to 8K
  • Batch downloads when supported by the selected source
  • Local MP4 or MKV file output
  • Available embedded and external SRT subtitle options
WHAT WE DON'T LIKE
  • Requires the local CoApp alongside the browser extension
  • Available quality depends on the source, platform, and service plan
  • The browser workflow is for Windows; macOS uses a separate desktop product
Frequently Asked Questions
Can I check CoApp's activity on Windows?
Yes. Open Windows Task Manager while starting or running a download and look for the CoApp process. StreamFab for Browser uses CoApp as its local Windows companion, so Task Manager provides a direct way to inspect its current activity and confirm that the browser extension can communicate with the installed component.
Does StreamFab for Browser connect to external servers during downloads?
Yes. StreamFab for Browser needs an internet connection to access the source website and retrieve the selected video. The browser extension handles detection and controls, while CoApp processes the download locally on Windows. Remote content access and local processing are separate parts of the same workflow.
What's the difference between StreamFab for Browser and the StreamFab desktop app?
StreamFab for Browser combines a browser extension with a local CoApp on Windows. The StreamFab desktop app is a separate standalone product. The browser range also offers distinct Netflix, Amazon, Disney+, Hulu, and M3U8 modules alongside the generic Video Downloader. Each option has its own service scope, specifications, and license; a downloader does not include a streaming subscription. Choose the matching option on the official browser product page.
Does StreamFab for Browser work on Android or macOS?
StreamFab for Browser is designed for Windows with Chrome or Edge. Its installer is not an Android APK or a macOS package. For macOS, use the separate StreamFab desktop download option; for Windows browser use, choose the official StreamFab for Browser download on the product page.
Does a free installer download include every browser module?
No. Downloading the installer starts the supported setup, but it does not grant a license for every browser module. The generic Video Downloader and service-specific modules are separate product options. Use the official trial or download option for the module that matches the website you want to access.
StreamFab Fits a Windows Browser Download Workflow
StreamFab for Browser fits users who want to detect authorized supported videos in Chrome or Edge and process downloads through a local CoApp on Windows. The workflow supports local MP4 or MKV output with available audio-language and subtitle options, while the source video and selected product module determine the available quality and features.
The practical advantage is keeping detection and download controls in the browser while CoApp handles local file processing. If that matches your workflow, use the official Windows installer and select the browser product option for the website you need.
StreamFab for Browser: Free Trial Download
Chrome and Edge extension with local CoApp processing, source-supported quality up to 8K, and MP4 or MKV output on Windows.
